[RPG]setting background image to formview
Post by MegumiSawada » Wed Feb 05, 2020 12:33 pm
Is it possible to set an image element to formview itself as background image?
I would like to put other elements on it.
Thanks in advance.
MarcusLancaster
Re: [RPG]setting background image to formview
Post by MarcusLancaster » Wed Feb 05, 2020 8:37 pm
Hi Megumi
I've done this in the past in RDMLX by adding the image to the form (using set_image with a local resource) and using the z_Index parm to push the image to the "back", and allow the primary user controls etc to float above it.
I would imagine that in RPG the same would be possible?
I guess it does depend on the particular scenario though and what controls you want to add to the form?
Anyway - hope that helps in your situation.
Cheers for now.
Marcus.
Post by MegumiSawada » Thu Feb 06, 2020 12:15 pm
Hi Marcus,
Oh, z_Index !!
I didn't think of it. I'll try it.
Thank you for your advice!
Regards, Megumi
