[RPG]properties can specifed for using AsReader
Post by MegumiSawada » Tue Jun 06, 2017 5:52 am
I would like to know all the property I can specify when using AsReader with Barcode element.
e.g.
Scan.Asreader : Y/N
Scan.Asreader.Beep : Y/N
etc,etc...
Could I ask it here?
Some customer asked us about it but these are not officially written in the guide either in English and Japanese.
The customer would like to know if they can still use vibration with AsReader.
Best Regards.
Re: [RPG]properties can specifed for using AsReader
Post by jasonzhou » Wed Jun 07, 2017 1:47 am
Yes, they can use "VibrateOnScan" property to enable vibration.
This is the explanation of "VibrateOnScan" in document - Indicates the intensity of vibration after successful scan (0 = off) Integer value from 0 - 10.
DDS Example:
     A                                  3 40HTML('<<SINGLEBC>>
     A                                      Type: Barcode
     A                                      MultipleEntries: No
     A                                      VibrateOnScan: 5
     A                                      Scanner.AsReader: Y
All properties of AsReader:
(1) Scanner.Asreader.ShowMsgInitTimeout
A Boolean value that specifies if a message should be shown at the bottom of the screen when LongRange fails to connect to AsReader.
(2) Scanner.Asreader.onConnectFail
An event that occurs when a AsReader fails to connect
(3) Scanner.Asreader.beep
Specifies the if the beep emitted from AsReader device after successfully scanning a barcode.
Jason
Post by MegumiSawada » Wed Jun 07, 2017 4:29 am
Hi Jason,
Thank you!
I will check the behavior.
