[RPG/JS]Get the value of GVAR
Post by MegumiSawada » Tue Aug 08, 2017 2:28 pm
I have an application to set the value of Textbox element to GVAR in javascript.
I'd like to show the value of that GVAR as a message of message box.
I thought I can retrieve the value of GVAR with "this.q_getProperties({"SharedStates.USERID":[]}); " statement, but i am not able to get the value.
TextBox WFUSID --> GVAR: USERID --> Messagebox
function() {
			this.q_setProperties("form.fields.WFUSID.Value.&.GVAR","USERID");
                         this.q_apply();
function(value1) {
        myMessage = this.value1;
        this.q_setProperties({
            runOperation:
                type: "ShowMessage",
                title: "Info",
                message: myMessage
How can I get the value of GVAR in the same javascript ?
I can pass the GVAR to the other formview, but I'm not sure how to get the value of GVAR within the same javascript.
mwilliams
Re: [RPG/JS]Get the value of GVAR
Post by mwilliams » Wed Aug 09, 2017 4:06 am
Try just doing
myMessage = value1;
Post by tsupartono » Wed Aug 09, 2017 9:23 am
Megumi,
You can also get a shared state value using the q_getState function - give that a try.
See the following section in the LongRange documentation site:
http://www.longrangemobile.com/docs/lrp ... evalue.htm
Use container type 0.
Also a quick reminder that any q_XXXX invocation must be the last statement in the current function.
E.g, the following is not allowed and will result in an undefined behaviour:
lrexec(
function() {
   q_setProperty...
   q_getProperty...
Instead you should break those 2 q_XXXXX invocation into 2 separate functions:
lrexec(
function()
   q_setProperty...
function()
   q_getProperty...
Post by MegumiSawada » Wed Aug 09, 2017 11:39 am
Hi mwilliams and Tony,
Thank you for your advice!
I was able to get the value of GVAR with the following code.
Your advice helped me a lot.
function() {
function() {
this.q_getProperty("SharedStates.USERID");
function(value4) {
        myMessage = value4;
Thank you!
