[RPG]fingerprint
[RPG]fingerprint
Is there any demo program & documents for fingerprint reading on LongRange?
Could I have it please?
Re: [RPG]fingerprint
Post by jasonzhou »
Please try this:
Function Options(*DIRECT)
Begin_Com Role(*EXTENDS #LRNG_FORM)
Mthroutine Name(HandleRequest) Options(*REDEFINE)
Define_Com Class(#PRIM_ALPH) Name(#UserName)
Define_Com Class(#PRIM_ALPH) Name(#Password)
#Com_Owner.Using Element('/Form.Fields')
Case Of_Field(#COM_OWNER.RequestACTION)
When (= LOGIN)
* Normal Login (using Username & Password)
#COM_OWNER.Get_TextBox Name(UserNameInput) Value(#UserName)
#COM_OWNER.Get_TextBox Name(PasswordInput) Value(#Password)
* Check if we should save user/password for fingerprint login
If (#COM_OWNER.Get( UseTouchIDCheckBox.Value ) <> '')
#COM_OWNER.Set Property('/Runoperation.Type') To(RegisterTouchID)
#COM_OWNER.Set Property('/Runoperation.UserName') To(#UserName)
#COM_OWNER.Set Property('/Runoperation.Password') To(#Password)
Endif
* Switch away from login page
#COM_OWNER.SwitchRequestPROGRAM := 'LREX0000'
When (= TOUCHID)
#COM_OWNER.Get Property('/Form.TouchID.UserName') InTo(#UserName)
#COM_OWNER.Get Property('/Form.TouchID.Password') InTo(#Password)
Otherwise
#COM_OWNER.Set Property('/Form.TouchID.Enabled') To(true)
#COM_OWNER.Set Property('/Form.TouchID.OnAuthenticated') To(TOUCHID)
#COM_OWNER.Set_TextBox Placeholder('Enter username') Layout_Row(1) Name(UserNameInput)
#COM_OWNER.Set_TextBox Placeholder('Enter password') Layout_Row(2) Name(PasswordInput)
#COM_OWNER.Set_Checkbox Layout_Row(3) Name(UseTouchIDCheckBox) Text('Allow login using fingerprint')
#COM_OWNER.Set_Button Layout_Col(1) Layout_Row(4) Text('Login') OnClick(LOGIN)
Endcase
#Com_Owner.EndUsing
Endroutine
End_Com
Post by jasonzhou »
Here is RPG demo code for your reference:
/free
        DoW (RequestPROGRAM = ProgramINFO.Name);
          Select;
            When (RequestACTION = 'ON_LOGIN');
              Exsr Login;
              IsNewForm = False;
            When (RequestACTION = 'ON_TOUCHID_AUTHED');
              Exsr TouchIDAuthenticated;
              IsNewForm = False;
            When (RequestACTION = 'ON_TOUCHID_CANCELLED');
              Exsr TouchIDCancelled;
              IsNewForm = False;
            When (RequestACTION = 'ON_TOUCHID_ERROR');
              Exsr TouchIDError;
              IsNewForm = False;
            Other;
              IsNewForm = true;
              Exsr EnableTouchID;
          endsl;
          Exsr DisplayFormView;
        Enddo;
        *InLR = True;
        Return;
        Begsr Login;
          USERNAME = LRNG_GetPropAsStr('/Form.Fields.UserName.Value');
          PASSWORD = LRNG_GetPropAsStr('/Form.Fields.Password.Value');
	  // get checkbox value to know if allow fingerprint logging next time
	  // if true, connect username and password with touch id
          If LRNG_GetBoolProperty('/Form.Fields.UseTouchIDCheckbox.Value');
            LRNG_Using('/RunOperation');
              LRNG_SetProperty('Type' : 'RegisterTouchID');
              LRNG_SetProperty('Username' : USERNAME);
              LRNG_SetProperty('Password' : PASSWORD);
            LRNG_EndUsing();
          Endif;
          MESSAGE = 'Login is successful. ' + 'Username: ' + USERNAME;
          LRNG_SetProperty('/Form.Fields.Info.Text' : MESSAGE);
        Endsr;
        Begsr EnableTouchID;
          If LRNG_GetSystemValue('HAS-TOUCHID-HARDWARE') = 'Y';
            LRNG_SetProperty('/Form.TouchID.Enabled' : 'True');
            LRNG_SetProperty('/Form.TouchID.OnAuthenticated' :
            LRNG_SetProperty('/Form.TouchID.OnCancelled' :
            LRNG_SetProperty('/Form.TouchID.OnError' :
          Endif;
        Endsr;
        Begsr TouchIDAuthenticated;
          LRNG_SetProperty('/Form.Fields.UserName.Value' :
                           LRNG_GetPropAsStr('Form.TouchID.Username'));
          LRNG_SetProperty('/Form.Fields.Password.Value' :
                           LRNG_GetPropAsStr('Form.TouchID.Password'));
          Exsr Login;
        Endsr;
        Begsr TouchIDCancelled;
            LRNG_SetProperty('Type' : 'ShowMessage');
            LRNG_SetProperty('Title' : 'Cancelled');
            LRNG_SetProperty('Message' : 'Touch ID login is cancelled');
          LRNG_EndUsing();
        Endsr;
        Begsr TouchIDError;
          MESSAGE = LRNG_GetPropAsStr('Form.TouchID.ErrorDescription');
                             'Error when authenticate Touch ID');
            LRNG_SetProperty('Message' :  MESSAGE);
          LRNG_EndUsing();
        Endsr;
        Begsr DisplayFormView;
          If (NOT IsNewForm);
            LRNG_SetSendChangesOnly();
          Endif;
          LRNG_Send();
          EXFMT FormView;
          LRNG_Receive();
          LRNG_GetRequestedAction(RequestPROGRAM:RequestACTION);
        Endsr;
      /end-free
     A                                       DSPSIZ(27 132)
     A          R FORMVIEW
     A                                  8 20HTML('<<USERNAME>>
     A                                      Type : TEXTBOX
     A                                      Placeholder: "User Name"
     A                                      ')
     A
     A                                 10 20HTML('<<PASSWORD>>
     A                                      Type : TEXTBOX
     A                                      Placeholder: "Password"
     A                                      ')
     A
     A
     A                                 12 20HTML('<<USETOUCHIDCHECKBOX>>
     A                                      Type : CHECKBOX
     A                                      Text: "Allow login
     A                                             using fingerprint"
     A                                      ')
     A
     A                                 14 20HTML('<<INFO>>
     A                                      Type : LABEL
     A                                      Color: RED
     A                                      ')
     A
     A
     A                                 18 20HTML('<<BUTTON>>
     A                                      Type : BUTTON
     A                                      Text: "Login"
     A                                      ONCLICK: ON_LOGIN
     A                                      ')
     A
Thank you!
Hi Jason,
Thank you for your code. I've checked the behavior and now understand it.
Two more questions:
1) If the device is used by multiple users(and all of them has already registered their fingerprint to the device),can we still use this Touch ID functionality ?
2) I believe LongRange does not support Biometric authentication other than finger print authentication.
Is it technically possible if the device support the Biometric authentication?
Thank you in advance!
Post by jasonzhou »
The Touch ID device can only tell if the fingerprint matches one of the enrolled fingerprints, in other words, it’s unable to tell if the fingerprints are from a single individual using multiple fingers or from various individuals using a single fingerprint. This means the mechanism will only work if the device is used by a single user. User should make sure only saving his or her own fingerprints on the device.
We'll do further investigation on it and will put reply in this topic https://longrange.lansa.com.au/viewtopic.php?f=11&t=603
