[RPG] subsystem AXESJSM
Rieko Saitoh
Post by Rieko Saitoh » Wed Apr 10, 2019 12:57 pm
Hi all,
I have installed LongRange for RPG, then subsystem AXESJSM has been created. I understand that this subsystem is created with aXes 4.1.0 or later versions.
I have a question about this subsystem.
Should the subsystem AXESJSM be started by executing a command (STRSBS AXESJSM/AXSJSM)? Or will it be started internally?
I am sorry without knowledge about the environment of LongRange for RPG. I am waiting for your answer.
Thank you.
Rieko Saitoh
LANSA japan
jmrapin
Re: [RPG] subsystem AXESJSM
Post by jmrapin » Thu Apr 11, 2019 11:51 am
Hi Rieko,
You are correct, the subsystem AXESJSM must be started using a command such as STRSBS AXESJSM/AXESJSM.
Hope this helps.
Rieko Saitoh
Post by Rieko Saitoh » Mon Apr 15, 2019 11:35 am
Hi Jean-Michel,
Thank you for your advice. It was very helpful for me!
Best regards,
Rieko Saitoh
LANSA japan
