Programming LongRange with JavaScript
eclink
Post by eclink » Fri Feb 28, 2014 2:22 am
Where can I find this documentation - Programming LongRange (RDMLX) with JavaScript ?
Re: Programming LongRange with JavaScript
Post by MarkDuignan » Sun Mar 02, 2014 4:45 pm
A copy of the JavaScript guide will be sent to your email address.
Documentation for RPG Developers
The additional and advanced topic guides are listed on this page and available up on request (made via this forum) http://www.longrangemobile.com/document ... vanced.htm
All other documentation is immediately accessible or downloadable from here http://www.longrangemobile.com/documentation.htm
Documentation for LANSA developers
The additional and advanced topic guides are listed on this page and available up on request (made via this forum) http://www.lansa.com.au/products/longra ... vanced.htm
All other documentation is immediately accessible or downloadable from here http://www.lansa.com.au/products/longra ... tation.htm
rgjohnson
Post by rgjohnson » Wed Mar 12, 2014 9:43 am
Can I also please get a copy of the advanced documentation for Programming LongRange (RPG) with JavaScript?
Post by MarkDuignan » Mon Mar 17, 2014 4:49 pm
"Programming LongRange with JavaScript" is generic - it applies to both RPG and LANSA programmers.
Did you mean the foundation and advanced RPG offline programming guides?
The advanced offline RPG guide contains some ECL scripted examples that use JavaScript.
Pat
Post by Pat » Tue Mar 18, 2014 4:34 am
Is there any doc showing the javascript object model for Long Range?
Post by MarkDuignan » Tue Mar 18, 2014 5:08 pm
There is only the "Programming LongRange with JavaScript" guide available. This is supplied upon request and it comes with executable examples (a schema + some code samples). See http://www.longrangemobile.com/document ... vanced.htm.
For the clarity of other forum readers – the primary programming languages for LongRange applications are RPG, COBOL and RDMLX (LANSA).
You might also choose to use use CL, C/C++ or JavaScript.
Any of those languages may be used independently - with no knowledge of any other language required - most especially JavaScript.
Pat
Post by Pat » Thu Mar 27, 2014 9:14 am
Great - could I get a copy of that please Mark?
Post by MarkDuignan » Wed Apr 09, 2014 8:33 pm
Did you get the material you need?
Pat
Post by Pat » Fri Apr 11, 2014 10:38 am
Yes thanks. Got the 2 x Offline PDF documents. I guess there isn't yet a doc of JavaScript aimed at RDMLX code.
Post by MarkDuignan » Sun Apr 13, 2014 5:35 pm
This may help you decide which guide or tutorial is appropriate - http://longrange.lansa.com.au/viewtopic.php?f=12&t=296
If these do not cover what you want to do then please put a post onto the forum.
