Is there any way to omit gap between subforms in table element?
I have tried to make multiple-lines table using subforms in table element.
I have used EXAM0077/D for sample.
However, there are some gaps between each subforms and I was not able to delete it...
Any advice would be appreciated!
Gap between subforms in table
- IMG_6811.PNG (174.3 KiB) Viewed 2624 times
- DEMOSWD23D.txt
- (4.05 KiB) Downloaded 238 times
- DEMOSWD23.txt
- (5.76 KiB) Downloaded 237 times
Re: Gap between subforms in table
Megumi,
Setting the 'CellPadding' property of the table to 0 should do the job.
Thank you! I got the expected result with CellPadding:0.
