(JavaScript API) LONGRANGE.Camera Image Dimensions
edwardtn
Post by edwardtn »
I am trying to define the resulting size of an image using the code below:
var opts = {};
opts.enableVideo = false;
opts.saveToPhotoGallery = false;
opts.enableAnnotation = true;
opts.size = { width: "640", height: "480" };
I searched the forum and found a link to a page illustrating how to set the dimensions for a portrait vs. landscape image.
http://www.longrangemobile.com/docs/lrp ... /image.htm
Can this also be done through the LONGRANGE.Camera JavaScript API? Is there a way to specify .LD/.PT?
Re: (JavaScript API) LONGRANGE.Camera Image Dimensions
Hi Edward,
Yes you can specify the landscape/portrait image dimension when using the JavaScript API.
The size.width and size.height properties have sub-properties "portrait" and "landscape".
You can specify both portrait and landscape value, or just either one (portrait or landscape, in which case the value of the other orientation will be derived).
opts.size = { width: {landscape: "640"}, height: {landscape: "480"} };
The code above indicates that images should be resized to 640x480 when they are in landscape, and 480x640 when in portrait
The code below indicates that images should be resized to 300x200 for landscape, and 150x250 for portrait:
opts.size = { width: {landscape: "300", portrait: "150"}, height: {landscape: "200", portrait: "250"} };
I'll also send you an updated JavaScript API guide that contains these properties.
edwardtn
Post by edwardtn »
Thank you. I received your email. This works perfectly.
Edward
