[RPG]showing navigation menu programmatically
On online form, I think you can show the navigation menu programmatically as follows:
if (RequestACTION = 'XXXXXX');
RequestPROGRAM = 'SYS-EXIT';
RequestACTION = 'SYS-EXIT';
Iter;
endif;
Is there any way to show the navigation menu programmatically on offline form?
(when touching a button,etc...)
Re: [RPG]showing navigation menu programmatically
You can show the main menu by using the ClientCommand operation with Command = MAINMENU.
This works for both online & offline forms.
Please see below for more information:
http://www.longrangemobile.com/docs/lrp ... ommand.htm
You can also indirectly show the main menu (as a side effect, which is how you get the menu presented using SYS-EXIT) by closing the form. If there is no other form currently visible, you will get the main menu as well.
You can close a form by executing the CloseForm operation (works for both online & offline forms).
http://www.longrangemobile.com/docs/lrp ... seform.htm
I have confirmed it works as expected.
Thank you!
