I have received the following question regarding LongRange behavior.
With NETSTAT command --> Option 3) will show "Work with TCP/IP connection status" screen.
When using LongRange client application, it seems connection will be add on this screen everytime LongRange client app connect to server.
I believe it is expected behavior, but the customer would like to check if it is no problem even though there may be huge amount of connection can occur at once.
TCP/IP Connection increases per server interaction
Re: TCP/IP Connection increases per server interaction
I think the behavior is correct.
After each request, the state will immediately become to Time-wait. (see Picture 1)
In TCP standard, Time-wait means that the connection is terminated, but before changes state to Closed, host needs to wait a short time to be sure the client received ACK flag. (see Picture 2)
This is what I read from https://en.wikipedia.org/wiki/Transmiss ... l_Protocol:
TIME-WAIT
(either server or client) represents waiting for enough time to pass to be sure the remote TCP received the acknowledgment of its connection termination request. [According to RFC 793 a connection can stay in TIME-WAIT for a maximum of four minutes known as two MSL (maximum segment lifetime).]
Thanks.
TIME-WAIT
Thanks.
- [Picture 1] the TCP state is Time-wait after each request
- ibmi.jpg (95.12 KiB) Viewed 3253 times
- [Picture 2] Time-wait will change to Closed after waiting a short time
- tcp_terminate.jpg (27.34 KiB) Viewed 3253 times
Hi Jason,
Thank you for your explanation.
I'll explain this to the customer!
