On an offline form view, I want to maintain an employee (which belongs to a department/section).
To facilitate the choice of the department/section to the user, I can display one dropdown with existing departments and one dropdown with existing sections. These dropdowns are populated/binded using local SQLite tables (Department and Section):
EZI_BindProperty( P1_DEPTMENT : 'VALUE' : 'FLD' : 'DEPTMENT');
EZI_BindProperty( P1_SECTION : 'VALUE' : 'FLD' : 'SECTION');
EZI_BindProperty( P1_DEPTMENT : 'ITEMTEMPLATE.VALUE'
: 'FLD' : 'DEPTMENT' );
EZI_BindProperty( P1_DEPTMENT : 'ITEMTEMPLATE.TEXT'
: 'FLD' : 'DEPTDESC' );
EZI_BindProperty( P1_DEPTMENT : 'ITEMLIST' : 'SQL'
: 'SELECT ROWID, DEPTMENT, DEPTDESC FROM Deptment');
EZI_BindProperty( P1_SECTION : 'ITEMTEMPLATE.VALUE'
: 'FLD' : 'SECTION' );
EZI_BindProperty( P1_SECTION : 'ITEMTEMPLATE.TEXT'
: 'FLD' : 'SECDESC' );
EZI_BindProperty( P1_SECTION : 'ITEMLIST' : 'SQL'
: 'SELECT ROWID, SECTION, SECDESC +
FROM Section'); // this display all Section records…
But I want to display in the section’s dropdown only the related sections of the displayed department. Any ideas how to achieve it?
Full RPG source is attached.
Yann
(RPG) Two related dropdowns on an offline form view
- YLEMPNO.txt
- (9.04 KiB) Downloaded 301 times
Re: (RPG) Two related dropdowns on an offline form view
Provided that the user/employee table is called EMPLOYEE:
In the section dropdown, we want to include only those sections that match the department of the employee you are currently editing.
The where clause would look something like this:
SELECT rowid, section, secdesc
FROM section
WHERE deptment = &(FLD:EMPLOYEE.deptment)
The first part (EMPLOYEE) in the notation &(FLD:employee.deptment) specifies where the field DEPTMENT should come from.
In this case, you want the field DEPTMENT to comes from a binding context called EMPLOYEE.
Binding context is formed when you bind a table or view with an element.
Any elements defined within another element (e.g elements within a form) can refer to the binding contexts of any of its parent elements.
Binding contexts are identifiable using their names. By default, when you bind a table to an element, the name of the binding context would be the name of the table. That's the reason why we can specify 'EMPLOYEE' in the &(FLD:EMPLOYEE.deptment) expression without having to explicitly specify a binding context name.
You can also designate a different name (alias) to a binding context. Setting up an alias is also mandatory if your view is a query (SELECT statement).
To designate an alias, use the 'AsView' binding property.
Example, we want to name our binding context USER (as opposed to the default EMPLOYEE).
LRNG_SetProperty('/Form.&.TBL' : Employee');
LRNG_SetProperty('/Form.&.AsView' : 'User');
You can then later refer to this binding context as 'USER' as opposed to 'EMPLOYEE':
WHERE deptment = &(FLD:USER.deptment)
FROM section
Thanks Tony. it works well.
