(RDMLX)Button in the table
Is it possible to make buttons in the table without a gap between facecolor and border(please see the attached pic)?
I tried padding(0)/cellspacing(0) but nothing changed. Innerpadding doesn't seem to exist.
HL44892.txt
(7.31 KiB) Downloaded 289 times
Re: (RDMLX)Button in the table
There are some properties that you could use to get this to look better.
Change the set up of your button to the following;
* Set up the button in column 6
#COM_OWNER.Set_Button Tablename('Table1') Tablecol_N(6) Buttonfacecolor(Yellow) Text('Select')
* Set the ButtonBorder properties for the button
#COM_OWNER.Set Property('Table1.COL%6.CONTENT.BUTTONBORDER.THICKNESS') To('1')
#COM_OWNER.Set Property('Table1.COL%6.CONTENT.BUTTONBORDER.COLOR') To('Red')
#COM_OWNER.Set Property('Table1.COL%6.CONTENT.BUTTONBORDER.CORNERRADIUS') To('5')
My tests show this removes the gap between the border and the Buttonface color,
I hope this works for you too,
Hi Paul,
Thank you for your advice.
It works!!
