(RDMLX) LRUSHOWPP : Show a popover message
stevec
Post by stevec »
I have been using this for the pop over field in error capability but it does not work on drop downs. Looking at the code I think it is due to changing the drop down to a text box on statement 64
#com_owner.Set_TextBox Show_Popover(True) Name(#com_owner.uOverElement.trim)
Has anyone enhanced this to look at the element type and set accordingly? What would code change need to be to get this to work with drop downs and other types?
stevec
Re: LRUSHOWPP : Show a popover message
Post by stevec »
Figured it out
#COM_OWNER.Get Property(#com_owner.uOverElement.trim + '.Type') Into(#ElementType)
Case Of_Field(#ELEMENTTYPE)
When Value_Is(= TextBox)
When Value_Is(= DropDown)
#com_owner.Set_Dropdown Show_Popover(True) Name(#com_owner.uOverElement.trim)
Endcase
stevec
Post by stevec »
This worked great until a component calls it that is "using" in which case the property is not found.
I tried many combinations but am having no luck getting the property type. What is the secret to get properting when "using"?
Mark_Dale
Re: (RDMLX) LRUSHOWPP : Show a popover message
Post by Mark_Dale »
I don't think in your case you need to get the element type, and handle the different types.
You could just use:
#Com_Owner.Set Property(#com_owner.uOverElement + '.ShowPopover') To('TRUE')
Mark_Dale
Post by Mark_Dale »
I don't think the problem getting the type of an element is due to the use of Using.
I think more likely it is because most properties are not returned by the client to the server (for performance reasons), and Type is one of those properties.
So this will not return anything to #lr_wkType
#Com_Owner.Using Element('/Form.Fields')
#COM_OWNER.IsNewForm := False
#Com_Owner.Get Property('MYTEXTBOX1.TYPE') InTo(#lr_wkType)
But this will return a value to #lr_wkValu (because the Value property of a textbox IS returned to the server)
#Com_Owner.Get Property('MYTEXTBOX1.VALUE') InTo(#vf_wkvalu)
And this will return a value to #lr_wkType (because the server has just set the Type property)
#Com_Owner.Set_TextBox NAME('MYTEXTBOX1') Layout_Row(2) Layout_Col(1)
#Com_Owner.Get Property('MYTEXTBOX1.TYPE') InTo(#vf_wkType)
stevec
Post by stevec »
Hmm
It has been consistently working to resolve type when not "nested using" and on some different types like dropdown and image.
You should only ever attempt to read (ie: get) properties that are marked as READABLE in the documentation.
Getting other properties would result in an undefined/unknown/unpredictable result and is not supported.
The READABLE marker against the property in the documentation indicates which properties you can reliably read/get.
