A followup question...
Does LongRange have full ATS support enabled?
This is the requirements that I found on the Apple developer site.
https://developer.apple.com/library/pre ... aKeys.html
Requirements for Connecting Using ATS
With ATS fully enabled, your app’s HTTP connections must use HTTPS and must satisfy the following security requirements:
The server certificate must meet at least one of the following trust requirements:
Issued by a certificate authority (CA) whose root certificate is incorporated into the operating system
Issued by a trusted root CA and installed by the user or a system administrator
The negotiated Transport Layer Security version must be TLS 1.2
The negotiated TLS connection cipher suite must support forward secrecy (FS) and be one of the following:
TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
The leaf server certificate must be signed with one of the following types of keys:
Rivest-Shamir-Adleman (RSA) key with a length of at least 2048 bits
Elliptic-Curve Cryptography (ECC) key with a size of at least 256 bits
In addition, the leaf server certificate hashing algorithm must be Secure Hash Algorithm 2 (SHA-2) with a digest length of at least 256 (that is, SHA-256 or greater).
I
f ATS is not enabled, the system still performs HTTPS server trust evaluation but you can override it on a case-by-case basis, as described in HTTPS Server Trust Evaluation. With ATS fully enabled, you cannot override the default HTTPS server trust evaluation.
The requirements listed in this section are current as of this document’s publication date, with stricter requirements possible in the future. Changes to these requirements will not break app binary compatibility.
