(RDMLX) Document Server
Posted: Thu Jun 13, 2013 8:06 pm
On the Document Server Setting screen of LongRange client app, it is written that "If no user is specified, your IBM i credential will be used when connecting to the document server". I wonder which user is actually pointed to. I mean, on LongRange for LANSA, there's no user provided explicitly.So I wonder which user will be used for the Document Server as a default.
I have another question.
Is there any way to make users use only LongRange Document server and to disable to use LongReach on their devices even if LongReach app is installed on these?
On LongReach(which is used for LongRange Document Server), you can allow/deny the useragent in httpd.xml. If you specify there like <deny useragent="longreach"/>,then both LongReach and Document Server get both disabled. So you cannot use this way,but do you know other way like this to achieve our requirement ?
Thank you in advance.
