(RPG) If you are using LongRange for RPG ...
Posted: Wed Mar 12, 2014 10:13 am
If you are using LongRange for RPG please do this test by executing the IBM I command:
DSPDTAARA DTAARA(LRNG_SOFT/VERSION)
You should see a version number formatted like this NNN-NNN-NNN-20131029
If the date shown is before 29th October 2013 then you should upgrade your server from here http://www.longrangemobile.com/upgrade.htm
After upgrading please try out the latest shipped demonstration and example schema LongRangeDemo.Lxp.
It has new demonstrations, examples and EZI capabilities - as detailed in the What’s New in this forum post http://longrange.lansa.com.au/viewtopic.php?f=13&t=226
