Suggestion for Logon - RDMLX
Posted: Fri May 02, 2014 3:18 am
by kno_dk
I have to build a longrange App for a customer. They want their customers to logon befor they can do more in the app. So, I have to build the menu so if the customer is not logon the only thing they can select is the logon. After succesful logon it should be possible to search for item and see price, stock and so on.
Do you have an exsample for this?
Is it possible to save the user/password on the device so next time they open the app they are logon?
Re: Suggestion for Logon - RDMLX
Posted: Fri May 02, 2014 9:07 am
by Mark_Dale
There is a basic example of logging on, and menu enablement, in shipped example LRULOGON (and LRULOGOFF)
To plug it in, you open the schema --> schema properties --> Application settings --> Setup Menu FormView
Posted: Sat May 03, 2014 1:39 am
by stevec
I customized the logon and did some things like newform false on a bad user/password so that did not need retyped, set my shared variables the cross forms to null, display a message from my all form plumbing component to check if system available (daily backups, timeout, etc) if it was redirected (and redirect right back after log on where they were), and also set the user who signed on as the current user (rather than the default http user) as we use that for many settings and normal lansa system variable derivations.
