set_image using LANSA
Posted: Wed Feb 11, 2015 2:27 pm
by jabain
Does anyone have any documentation on parameters for the set_image method?
I found the LREX0017 sample, but I am not finding any detailed documentation on the features of this functionality.
Andy
Re: set_image using LANSA
Posted: Wed Feb 11, 2015 2:36 pm
by Paul
The doco is here..
http://www.longrangemobile.com/docs/lan ... /image.htm
If you look at the features for the method in the LANSA IDE it will give you the names of the parameters.
Please post again if you can't find the information you need.
Posted: Thu Feb 12, 2015 7:06 am
This also worth knowing about re setting properties -v- passing specific parameter methods -
http://www.longrangemobile.com/docs/lan ... inglon.htm
