(RDMLX) set element's value for Paramvalue of Set_EventParameter.
Yukiko Ikeo
Post by Yukiko Ikeo »
I'd like to set element's value for Paramvalue of Set_EventParameter.
(ex. the value of the textbox, the text of the label)
The coding below doesn't work as expected.
* elements
#COM_OWNER.Set_TextBox Name(TEXT) Value('ABCDE') Layout_Col(1) Layout_Row(1) Maxlength(20)
#COM_OWNER.Set_Label Name(LABEL) Layout_Col(1) Layout_Row(2) Text('Label') Border_Thickness(1)
* set event parameter
#COM_OWNER.Set_EventParameter Event(BUTTON.Onclick) Param_N(1) Paramvalue(TEXT.Value)
#COM_OWNER.Set_EventParameter Event(BUTTON.Onclick) Param_N(2) Paramvalue('/Form.Fields.LABEL.Text')
How can I set element's value as the other method's parameter?
Yukiko Ikeo
Re: (RDMLX) set element's value for Paramvalue of Set_EventParameter.
I think you need to get the value first into a field - then set from the field.
ie: Your reference to TEXT.Value is really just the string "TEXT.VALUE" to the RDMLX code generator - it has no special meaning.
Yukiko Ikeo
Hi Mark,
Thank you for your reply.
The coding below worked as expected.
#COM_OWNER.Using Element('/Form.Fields.TEXT') Alwaysrememberlast(True)
#COM_OWNER.Get Property(Value) Into(#STD_TEXT)
#COM_OWNER.EndUsing
#COM_OWNER.Set_EventParameter Event(BUTTON.Onclick) Param_N(1) Paramvalue(#STD_TEXT)
#COM_OWNER.Using Element('/Form.Fields.LABEL') Alwaysrememberlast(True)
#COM_OWNER.Get Property(Text) Into(#STD_TEXTL)
#COM_OWNER.EndUsing
#COM_OWNER.Set_EventParameter Event(BUTTON.Onclick) Param_N(2) Paramvalue(#STD_TEXTL)
Thank you for your help.
Best regards, Yukiko Ikeo
