[RDMLX]Set_sendmessage requires Event property
When you would like to show message box on the form, you will write like this:
#Com_Owner.Set_Sendmessage Event('/Form.Onload')
In RPG, there's no "event". You just need to write "RunOperation" where you would like to run the operation.
LRNG_USING('/RUNOPERATION');
  LRNG_SETPROPERTIES(
    'TYPE : SHOWMESSAGE'
   :'TITLE : Confirm '
   :'MESSAGE : Do you want to upload data?'
   :'CANCELBUTTONIDX : 2'
   :'BUTTON%2.TEXT : No'
   :'BUTTON%1.TEXT : Yes'
LRNG_ENDUSING();
Why we need to specify Event property in RDMLX, not only writing Set_Sendmessage method where you would like to run the operation like RPG?
Re: [RDMLX]Set_sendmessage requires Event property
You can use either OnLoad event or RunOperation in your RPG and RDMLX programs.
Here is an example of OnLoad event in RPG:
LRNG_AssignStrToProp('ShowMessage' : '/Form.OnLoad.Operation.Type')
LRNG_AssignStrToProp('This is an example!' : '/Form.OnLoad.Operation.Text')
Conversely, you can use the RunOperation in RDMLX:
#COM_SELF.Set Property('/RunOperation.Type') To(ShowMessage)
#COM_SELF.Set Property('/RunOperation.Text') To('This is an example!')
For online forms, RunOperation and the form's OnLoad event have the same effect and will yield the same result.
However, RunOperation is not applicable and can't be used in offline forms - you must use OnLoad event if you want your code to run when a form is loaded.
I see. Thank you.
I will tell this to the customer.
