Is there any way to retreive the current URL of imbedded webview in formview?
You can define start url for imbedded webview in a formview(for example, http://www.lansa.com).
Then user can move to other website on that webview(for example, http://www.lansa.jp/index.htm).
Is it possible to retreive the current URL of it then ?(for example, http://www.lansa.jp/index.htm)
I tried it with
WRKURL = LRNG_GetPropAsStr('/Form.Fields.SITE1.URL');
but it seems it doesn't work.
[RPG]Retreive the current URL
Re: [RPG]Retreive the current URL
This might be possible with some JavaScript ECL. You would have to create some sort of web page/frame container to run the web pages in and then set the current URL into a shared state variable. The complexity is that the web browser is out on the client and your RPG program is on the server – so you have to pick up the value on the client and send it to the server.
Even attempting this is a moderately complex task – and there is no guarantee that it will succeed or that it will exactly match the requirement.
How important is the requirement -versus- the possible complexity and cost of implementing it?
One question – are the web pages owned by the customer/client – or can they be any web pages anywhere?
I’m asking because if they are owned there is also a possibility of approaching this the other way around – by getting the web page(s) to post something that tells the server who is where.
Hi Mark,
Thank you for your reply.
I see.
I'll ask our customer for more detailed requirement and let you know if more information/consideration required.
Thank you!
I see.
Thank you!
