RDMLX - Dropdown Lists in Tables
Is it possible to have a dropdown list in a table? I want to display a list of items to the user with the option to set one of approved, declined or n/a for each item then click a save button. In a web function would have used a set of radio buttons but this does not appear to be supported in Longrange.
Re: RDMLX - Dropdown Lists in Tables
Sure, you can do a SET_Dropdown for a row/column in a table. You would give it a "row unique" name and onChange value and it should work just fine. You will have to populate each dropdown individually.
David
David
Also, please note that if you are still using the beta version of LongRange LANSA the GA version is available from the web site.
http://www.lansa.com/products/longrange/index.htm
Thanks for that. It worked as advertised.
