Document library on Windows server
I believe Document library use LongReach and LongReach works only on IBM i.
If the server is Windows server, can we use Document library?
If no, what does the following URL mean?
http://www.longrangemobile.com/docs/lrl ... ervers.htm
Megumi sawada
Re: Document library on Windows server
You can most definitely use LongReach on Windows, as indicated in the documentation.
If you encounter an issue with LongReach installation, you might get a faster/better response if you ask in the LongReach forum, or contact LANSA Support.
Oh does it work on Windows server too?
Thank you for your information.
