[RDMLX]Offline External Invocation Handler
I have a requirement to invoke longrange offline form from URL.
I can fire up javascript via the target form's onload event to open offline form. However how can I get the inbound parameters from the URL?
I have found the following topic and it seems we were not able to pass a parameter to offline form at that time(on 2014).
http://longrange.lansa.com.au/viewtopic ... =260&p=661
Is it still not possible?
Re: [RDMLX]Offline External Invocation Handler
Megumi,
You can read the URL parameters from your offline form.
Here is how you pass parameters in the URL:
longrange://performaction/?param,1=testvalue1&param,2=testvalue2
The above example pass 2 parameters (testvalue1 and testvalue2)
In your JavaScript code (the offline form's OnLoad handler), you read the parameters by invoking receiveVars:
lrexec(
    function()
        this.q_receiveVars("args");
    function()
        this.console(this.args[0]); // first argument = testvalue1
        this.console(this.args[1]); // second argument = testvalue2
I have been able to achieve what I would like to do based on you advice.
Thank you!!
