【RPG】VPN connection switching with LongRange
sohashi
Post by sohashi »
Application of long range for RPG
Can I turn on / off the VPN connection of smart device with LongRange?
Shumpei Ohashi
Re: 【RPG】VPN connection switching with LongRange
Post by jasonzhou »
Hi Shumpei,
Could you please give us more details about this - Would you like to turn on/off the VPN in LongRange? Or you just want to know if LongRange works ok when device is in a VPN environment.
Jason
sohashi
Post by sohashi »
Hi Jason
I want to switch VPN on / off with LongRange.
Shumpei Ohashi
Post by jasonzhou »
Hi Shumpei,
iOS system has this feature that let app to make a VPN connection. However there are some limitations:
(1) it only support IPSec and IKEv2
(2) with IPSec, the PAP authentication protocol is not supported
Moreover, when submit to App Store, Apple ask to make a clear declaration of what user data will be collected and how it will be used, so it's better to implement the VPN feature in custom version.
If you'd like check if iOS VPN client works ok with VPN server, I can provide a test build to you to test.
Jason
