[RPG/RDMLX]Id in the LognRange profile
I've configured LongRange profile on the device manually at first and I would like to update that profile with auto-configuring feature from URL.
What would be set to "Id" when manually set at first?
I would like to specify that Id in the URL to update.
Auto-Configuring LongRange from a URL
https://www.longrangemobile.com/docs/lr ... omaurl.htm
Re: [RPG/RDMLX]Id in the LognRange profile
Post by jasonzhou »
The id is only for identifying the profiles created from URL. The manually created profile doesn't have an identifier so it can't be updated by URL.
You can export your manually created profile and import it again via URL, see below steps as your reference:
1. Export profile to an URL in Settings - Tools - Export Server Profiles
2. Set an id for this profile (for example: prf,1.id=prf1)
3. Put the URL in an html page and click it on device to create a profile in LongRange
4. Next time you can update this profile from URL with id "prf1"
I see.
Thank you for your instruction.
