Hi all.
Quick question - is there a way to convert to/from BASE64 in client side LR javascript?
Cheers for now.
Marcus.
BASE64 Conversion
Re: BASE64 Conversion
There are two JavaScript functions btoa() and atob() can do BASE64 encoding/decoding. (https://developer.mozilla.org/en-US/doc ... d_decoding)
For exmaple:
var encodedData = window.btoa('Hello, world'); // encode a string
var decodedData = window.atob(encodedData); // decode the string
For exmaple:
MarcusLancaster
Hi Jason.
Thanks for this - I'll give it a try.
Cheers.
Marcus.
Cheers.
Marcus.
atob and btoa may not work if there is no JavaScript window context, so the following code would satisfy the requirement.
- Encode byte array
function base64EncodeByteArray(byteArray)
const BASE64CODE = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
var result = "";
var restBytes = byteArray.length % 3;
var byteBlocks = byteArray.length / 3;
var index = 0;
if (byteBlocks >= 1)
for (var i = 0; i < byteBlocks; i++)
var block = (byteArray[index++] << 16) | (byteArray[index++] << 8) | byteArray[index++];
result += BASE64CODE[(block&0xFC0000)>>18] + BASE64CODE[(block&0x3F000)>>12] + BASE64CODE[(block&0xFC0)>>6] + BASE64CODE[(block&0x3F)];
var remainingBytes = byteArray.length - index;
switch(remainingBytes)
case 1:
var block = byteArray[index]
result += BASE64CODE[(block&0xFC)>>2] + BASE64CODE[(block&0x03)<<4] + "==";
break;
case 2:
var block = (byteArray[index] << 8) | byteArray[index+1];
result += BASE64CODE[(block&0xFC00)>>10] + BASE64CODE[(block&0x03F0)>>4] + BASE64CODE[(block&0x0F)<<2] + "=";
break;
return result;
- Encode binary data read from SQLite database with hex() function
function hexStrToBase64(hexString)
if (hexString.length % 2 == 0)
var bufferIndex = 0;
var buffer = new Uint8Array(hexString.length/2);
for(var i=0;i<hexString.length;i+=2)
var c1 = hexString.charAt(i);
var c2 = hexString.charAt(i+1);
var i1 = parseInt(c1,16);
var i2 = parseInt(c2,16);
var data = i1<<4 | i2;
buffer[bufferIndex++] = data;
var result = base64EncodeByteArray(buffer);
return result;
MarcusLancaster
Excellent - thanks for the follow-up post Jason
