Session variables
stevec
Session variables
Post by stevec »
are they stored by schema or across all schemas?
Curious if I have a variable for example for "MobileApp" and log in to app = "A" and it gets set. Then without closing and open another schema for "B" do I have 1 variable now "B" or 2 variables "A" and "B"?
Re: Session variables
Post by jasonzhou »
Does the "Session variables" mean /SysStates or /SharedStates? Both of them are stored by schema.
Thanks.
stevec
Post by stevec »
Sharedstates.
Is there a way the user can clear them out somehow on iphone?
Post by jasonzhou »
User can't clear it. You need to programmatically clear them. Thanks.
stevec
Post by stevec »
Somehow it appears a (or all) session variable is getting cleared or corrupted.
How can I close the app programatically when this occurs?
Post by jasonzhou »
Unfortunately, there is no way to programatically close the app. Can you please have a look is it possible that server program cleared the session variable?
stevec
Post by stevec »
No it is not possible. I am adding code to send me an email with as much info as I can grab about device and key session variables. And then route back to login. Problem is that I have 3 apps and if the app session variable is corrupt then I do not know what login to route them back to.
Post by jasonzhou »
Does this happen randomly? Is it easy to reproduce this issue?
stevec
Post by stevec »
No I cannot reproduce, seeing it happen occasionally on a customers box that is why I put in an error trap and sending myself email with info to help debug.
Post by jasonzhou »
Thanks for letting us know this. We will do some test with Sharedstates see if we can reproduce the issue first. If next time you can reproduce it and have client log, please send it to us via LANSA support.
