Here's an FYI for anyone using or planning to use virtual environments on their development PC. If your virtual environment requires that you turn on the Hardware Virtualization settings in the BIOS of your machine, this will impact your LongRange Developer Certificates on that machine. You'll have to resubmit the machine info to get new certificates. There's no charge to get them but be aware that you'll have to submit the request so plan accordingly. BTW, turning the virtual settings back off will allow the existing certificates to be valid again if you need temporary relief.
jimk
