(RPG) APIs provided in LongRange to aid you in common tasks
LongRange includes some simple to use APIs that help you perform common tasks.
For example – writing a file out into the IFS ................
   // Open as UTF-8 using standard IBM i file open/reopen technique.
    //  Local.RetCode is declared asa 10I00 (integer) field.
    //  The open is actually done by the ILE C library 'fopen' function.
    //  See http://publib.boulder.ibm.com/infocenter/iadthelp/v6r0/index.jsp
    //          ?topic=/com.ibm.etools.iseries.langref.doc/rzan5mst115.htm
    //  for what all the second parameter options are.
    Local.RetCode = LRNG_FileOpen('/TestFile.html' : 'w,o_ccsid=1208');
    If (Local.RetCode <> 1);
      // The open has failed. In fact all LRNG_file operations
      // will return a 1 if they complete normally - otherwise
      // they return a value < 1. Running with LRNG_SystemTraceOn()
      // will normally trace out the exact IBM i errno or message.
    Else;
     // Close and reopen so that all future data written is converted from
      // current job’s CCSID
     LRNG_FileClose();
     LRNG_FileOpen('/TestFile.txt': 'w,o_ccsid=0');
      // Write out data
     LRNG_FileWrite('<html><head></head><body>':0);
         LRNG_FileWrite('<div>Hello World</div>':0);
         LRNG_FileWrite('<div>Hello World Again</div>':0);
         LRNG_FileWrite('<div>Hello World Finally</div>':0);
      LRNG_FileWrite('</body><html>':0);
     // Close the file
      LRNG_FileClose();
    Endif;
