What Languages are supported?
EugeneKing
Post by EugeneKing »
What Languages are supported in LongRange? Is Turkish supported?
Re: What Languages are supported?
Not at the moment.
We can easily incorporate Turkish texts if you provide the translated resource files.
Send me an email if you need to do this.
Jiri
Re: What Languages are supported? Czech Added
Post by Jiri »
The translation is easy possible, it only takes some time. Some time ago I made Czech translation and it works well. The LR language is automatically selected by language set on device, so when I set device language to ENG, the LR environment works in English, when I set Czech, it works well in Czech. If LR application was running when you change the language settings, it requires restart only the application, not the whole device. No language settings is required in LR and you are using the same app. The text resources are coded UTF8, therefore don't worry about national characters problem.
