LR for LANSA install check on iSeries/LANSA system
What's the best/quickest way to check that LR for LANSA is installed and operational on an iSeries/LANSA system?
Paul
Re: LR for LANSA install check on iSeries/LANSA system
The only way to be sure is to install LongRange client and try to run the Demo schema. This way will, somewhere, indicate the nature of any problem if it doesn't run.
E.g. - If you can see the schema, but cannot run a simple form (e.g. Examples - Introductory - Hello world)
Check whether any simple wam can be run in lansa
- If that fails
Check whether lansa for the web is operational
- If you can't display the schema in the client check the authority and web visibility of the LANSADemo.lxp file.
In the development team all imports and builds are tested this way. I'm not aware of any shorts cuts.
- If that fails
