(RPG)a label above a table
Posted: Wed Nov 20, 2013 2:02 pm
by MegumiSawada
- IMG_0099Z.jpg (33.59 KiB) Viewed 5734 times
I've created a formview which has a label above a table.
However there's a gap between the label and table but I don't want to have a gap between them.
Is there anyway to delete this gap?
I've created a table without any border but I put a border around every items.
The label is defined 1 row upper than the table.
Table has no header.
I appreciate your advice...
Re: (RPG)a label above a table
Posted: Fri Nov 22, 2013 9:20 am
By default all the cells on a form are spaced out.
The label is in one cell, the table in another - so try LRNG_SetNumProperty('/Form.Grid.Cellspacing' : 0 );
If you still have space you could try setting the padding on the label and table to zero.
Posted: Fri Nov 22, 2013 12:21 pm
by MegumiSawada
Thank you,Mark.
It's better, but still it has a gap.
And when I re-load the formview,the gap become bigger...I don't know why.I'll find out.
If you have any other idea, could you please let me know?
Otherwise I'll tell the customer this.
Posted: Fri Nov 22, 2013 12:42 pm
Can you send me your RPG code?
Posted: Fri Nov 22, 2013 3:06 pm
by MegumiSawada
Hi Mark,
These are my sample code.
Thank you,
Posted: Fri Nov 22, 2013 3:28 pm
Try making the table do this:
and make the program do this:
LRNG_SetNumProperty('/Form.Padding' : 0 );
Posted: Fri Nov 22, 2013 4:11 pm
by MegumiSawada
Thank you,Mark!
I was able to have an expected result with making the table with padding and innerpadding zero, and making RPG code to use LRNG_SetNumProperty('/Form.Grid.Cellspacing' : 0 );
Perfect.
Thank you again!
