Is it possible to display numeric values with comma(,) on offline form?
On Online form it can show the numeric values with comma(,) when using Set_Label.
e.g.
Define Field(#FLDN070) Type(*dec) Length(7) Decimals(0) Edit_Code(1)
#COM_OWNER.Set_Label Name(FLDN070) Layout_Row(5) Layout_Col(2) Text(#FLDN070.AsDisplayString)
On Offline form,is it possible to do so?(either for Label/Textbox)
If so, could you please let me know how?
e.g.
#Com_Owner.Set_Label Layout_Row(5) Layout_Col(2) Name(TB_SALARY)
#Com_Owner.Set_Binding Name(TB_SALARY) Property(VALUE) Bindtotype(FLD) Bindto('Salary')
Re: display numeric values with comma(,) on offline form
I think I found a solution for this. I need to write javascript to do this.
Assume there're a text box named "TB_EMPNO" and a label named "LB_Salary" on the form.
The value of LB_SALARY will be formatted with comma.
I don't know it is a smart way.
lrexec(
function()
this.q_getProperty("Form.Fields.TB_EMPNO.Value");
function(value1)
this.EMPNO = value1;
this.q_sendVars("EMPNO");
function()
this.q_sql('SELECT Salary FROM Employee WHERE Empno = ?EMPNO','scalar');
function(value2)
var myTextBox1 = value2;
var num = new String(myTextBox1).replace(/,/g, "");
while(num != (num = num.replace(/^(-?\d+)(\d{3})/, "$1,$2")));
var myResult = num;
this.q_setProperty("Form.Fields.LB_SALARY.Text", myResult );
null
We'll add the ability to specify thousand separator (in NumberTextFormat) in the next release.
Thank you for that.
Thank you for that.
