retrieving the host and port from a session definition
dhnaigles
Post by dhnaigles »
We have an ISV who wants to discover the server host and port from the longrange mobile session definition. This host:port may be different for every customer and is the "prefix" to the WebView URL. Currently they are hard-coding this in the server-side code. Are there any methods to retrieve this information dynamically?
David
Re: retrieving the host and port from a session definition
RPG or RDMLX customer?
dhnaigles
Post by dhnaigles »
RDMLX
David
Post by stevec »
Is this going to be done?
If I can retrieve it then I would not have to hard code (or put in a data area or DB file) the port.
Even better would be ability to use relative path dot dot (..) like we can on Wams.
Yes this is done in RV16 - out to be released in a week or so.
Post by stevec »
Thank u
Post by stevec »
I am not seeing where I can get server/port?
The R16 doc 2nd point in other enhance says can use relative path now which is what I really want for my pdf's
my request dot dot (..) like wams is not it ...
Mark_Dale
Post by Mark_Dale »
My understanding of the relative URL rules are:
1. When using Open URL (#Com_Owner.Set_OpenURL)
a) start with / means relative to the WEBSERVER ROOT directory.
/images --> Http://myip:myport/images
b) start with nothing means relative to the LONGRANGE ROOT directory
resource/abacus.png --> http://myip:myport/images/Longrange/resource/abacus.png
c) or specify the full url
2. When defining a web view in the schema (as at RV16)
a) start with / means look for the local copy of a file in the Longrange/resource directory
b) start with ./ means relative to the LONGRANGE ROOT directory
./resource/abacus.png --> http://myip:myport/images/Longrange/resource/abacus.png
c) start with nothing means relative to the LONGRANGE ROOT directory
d) or specify the full url
Post by stevec »
The slash "/" for relative to webserver directory also worked for set_webview
