How can I get image or voice clip size?
Post by stevec »
for saving to blob with size info field.
Is there an easier way than doing a directory list )ov_file_service get_dir) and locate fiel in list which has file size?
Re: How can I get image or voice clip size?
I can't think of any other was in RDMLX.
However - you might find some other solutions to retrieve an IFS file size in the general IBM i community forums?
If you can wrap the logic up in a program you should be able to call it from your RDMLX code.
There is a standard IBM API called stat() or fstat() https://publib.boulder.ibm.com/infocent ... Ffstat.htm
that can return this information. You could call that from a very small CL program that binds to I think.
What OS/400 (iOS) version are you using?
Post by stevec »
I created an rpg procedure (and wrapper for lansa since it does not support them) for stat and it works for files size.
is it possible to post the code - it would probably be useful to other forum users.
Post by stevec »
ifsgetsiz_rpglemodule.txt
(1.58 KiB) Downloaded 255 times
getifssizw_rpglewrapper.txt
(1.39 KiB) Downloaded 270 times
ifsgetsiz_rpgleproto.txt
(885 Bytes) Downloaded 246 times
http://www.scottklement.com/rpg/ifs.html
for ifsio_h include
Thanks for that.
Here's another useful IFS file program I encountered today - http://www.itjungle.com/fhg/fhg051414-story02.html
