How to display both icon and text in primary command area
MasakiSuzuki
Post by MasakiSuzuki »
hi,
If you set both the text and the icon in the primary command area, only the icon appears.
Is there a way to display both the icon and text?
Masaki Suzuki
Paul
Re: How to display both icon and text in primary command are
Post by Paul »
Good Morning,
Could you give a little more detail on how you are trying to set the text and icon?
MasakiSuzuki
Sorry, I write in detail below.
The primary area:
The secondary area:
Results screen:
I want to display icon + text, as secondary command area.
Is there any way?
Paul
Post by Paul »
Does it work if you set the Symbolic name?
Also make sure you are editing the correct object, Menu item or Target object.
Another thing is to check the display style.
Let us know how you go.
MasakiSuzuki
Hi Paul,
Behavior did not change even if I set the symbolic name.
I was sure that I am editing the correct object, and that the default is set to display style
Be displayed in the 'icon + text' to the primary command area do you impossible?
I don’t think you can have both icons and text.
The default appearance may also change between iOS and Android and between large/tablet and small/phone devices.
MasakiSuzuki
Hi All,
I have understood that the specification is that I can not be displayed.
I would like to thank all of reply.
