For LongRange RPG users only …………
We have encountered two instances in the last year of IBM i data queues in library LRNG_TEMP becoming ‘damaged’.
IBM i object damage is most likely to happen when your IBM i terminates abnormally (eg: a power outage with no UPS).
The risk of this type of object damage causing an operational problem can be eliminated by clearing library LRNG_TEMP when restarting after an abnormal IBM i shutdown. Use the CLRLIB command to do this.
Alternatively, many sites shutdown their QINTER and AXES subsystems regularly (eg: every night). So if you always clear LRNG_TEMP before restarting subsystem QINTER and AXES you would eliminate this risk and minimize disk space usage.
IBM i Data Queue damage
Re: IBM i Data Queue damage
LongRange RPG incorporates the aXes product.
The following aXes Administrators guide section talks about when to stop and restart aXes.
This is the point where including a CLRLIB LRNG_TEMP would be beneficial
- Guide
- Capture.PNG (27.72 KiB) Viewed 15111 times
