Shared States Replacement
If I replace all of the Get_SharedState and Set_SharedState commands in my application with selections and assignments to a server based table will the existing shared states still be sent back and forth between the client and server and if so is there a way to stop this from happening ?
Re: Shared States Replacement
Yes the existing shared states will continue to be sent back and forth.
Unfortunately there is no way to delete the shared states.
The only possible solutions at this stage:
(1) Set the value of the shared states to empty string
(2) Reinstall the LR client
