TCP/IP Connection increases per server interaction
Posted: Thu Jan 19, 2017 6:24 pm
I have received the following question regarding LongRange behavior.
With NETSTAT command --> Option 3) will show "Work with TCP/IP connection status" screen.
When using LongRange client application, it seems connection will be add on this screen everytime LongRange client app connect to server.
I believe it is expected behavior, but the customer would like to check if it is no problem even though there may be huge amount of connection can occur at once.
