[RDMLX] Bind a dropdown as a table column to SQL table
Taku Izumi
Post by Taku Izumi »
HI,
Can bind a dropdown as a table column to SQL table?
I am trying to do it using this code. But, the result is a property unrecognized error.
#COM_OWNER.Set_Table Name(Table1) Layout_Col(1) Layout_Cols(-1) Layout_Row(3) Border_Cornerradius(10) Border_Thickness(1) Border_Color(Blue)
#COM_OWNER.Set_Table Name(Table1) Col_N(1) Col_Name(TBDD1) Col_Width(100) Col_Type(DropDown)
#COM_OWNER.Set_Label Name(Table1.Col%1.Header) Text('DropDown Column') Textalign(Center)
* Bind a dropdown to SQL table
#Com_Owner.Set_Binding Name('Table1.TBDD1.ItemTemplate') Property(Text) Bindtotype(FLD) Bindto('DDText')
#Com_Owner.Set_Binding Name('Table1.TBDD1.ItemTemplate') Property(Value) Bindtotype(FLD) Bindto('DDValue')
#Com_Owner.Set_Binding Name('TABLE1.ROW%1.TBDD1') Property(itemlist) Bindtotype(SQL) Bindto('SELECT DDText, DDValue FROM DDTable')
#Com_Owner.Set_Binding Name('TABLE1.ROW%2.TBDD1') Property(itemlist) Bindtotype(SQL) Bindto('SELECT DDText, DDValue FROM DDTable')
#Com_Owner.Set_Binding Name('TABLE1.ROW%3.TBDD1') Property(itemlist) Bindtotype(SQL) Bindto('SELECT DDText, DDValue FROM DDTable')
Taku
Re: [RDMLX] Bind a dropdown as a table column to SQL table
The propery reference (Table1.TBDD1.ItemTemplate) in this line below doesn't look right:
To refer to a column, you'd need to use COL%N property.
Try TABLE1.COL%1.Content.ItemTemplate
#Com_Owner.Set_Binding Name('Table1.COL%1.Content.ItemTemplate') Property(Text) Bindtotype(FLD)
Taku Izumi
I tried to this code.
However, it dose not be recognized a property.
This error message shows.
The error message is:
The following properties are not recognized:
FORM.FIELDS.TABLE1.COL%1.CONTENT.ITEMTEMPLATE.VALUE.$3.FLD
FORM.FIELDS.TABLE1.COL%1.CONTENT.ITEMTEMPLATE.TEXT.$3.FLD
FORM.FIELDS.TABLE1.ROW%1.TBDD1.ITEMLIST.$3.SQL
FORM.FIELDS.TABLE1.ROW%2.TBDD1.ITEMLIST.$3.SQL
FORM.FIELDS.TABLE1.ROW%3.TBDD1.ITEMLIST.$3.SQL
Best regards,
Taku
