Could you pelase let me know how to use ZINDEX?
https://www.longrangemobile.com/docs/lr ... erties.htm
If I would like to use 3 different sub-form in the same position in a formview, can I use ZINDEX for these sub-forms?
I would like to switch these sub-forms by clicking on button.
If possible, could I have a sample code for them please?
[RPG]How to use ZINDEX
Re: [RPG]How to use ZINDEX
Attached demo code shows how to use ZIndex with 3 sub-forms.
- FORMZIDX.txt
- (5.86 KiB) Downloaded 329 times
Hi Jason,
Thank you for the sample code.
Can we use DDS as well?
In that case, how can we define 3 sub-forms in the same position?
Can you please try Layout.row and Layout.col in DDS see if it works as expected?
For example:
For example:
A 20 20HTML('<<FORM1>>
A Type: Form
A Layout.row : 1
A Layout.col : 1
A Layout.Width : 50
A Layout.Height : 50
A BackColor : Gray
A ')
A 20 20HTML('<<FORM2>>
A Type: Form
A Layout.row : 1
A Layout.col : 1
A Layout.Width : 50
A BackColor : Red
A ')
A 20 20HTML('<<FORM3>>
A Type: Form
A Layout.row : 1
A Layout.col : 1
A Layout.Width : 50
A BackColor : Yellow
A ')
Hi Jason,
Thank you for your reply.
It seems that only the last definision(e.g. FORM3) will be recognized becase 3 subforms are at the same position.
So the last difinision is shown initially and an error will occur when tapping buttons.
Layout.col and Layout.row doesn't seem to work as expected.
