[RPG]How to use ZINDEX
Posted: Wed Jul 03, 2019 12:57 pm
by MegumiSawada
Could you pelase let me know how to use ZINDEX?
https://www.longrangemobile.com/docs/lr ... erties.htm
If I would like to use 3 different sub-form in the same position in a formview, can I use ZINDEX for these sub-forms?
I would like to switch these sub-forms by clicking on button.
If possible, could I have a sample code for them please?
Re: [RPG]How to use ZINDEX
Posted: Thu Jul 04, 2019 9:31 am
by jasonzhou
Attached demo code shows how to use ZIndex with 3 sub-forms.
Posted: Thu Jul 04, 2019 12:02 pm
by MegumiSawada
Hi Jason,
Thank you for the sample code.
Can we use DDS as well?
In that case, how can we define 3 sub-forms in the same position?
Posted: Thu Jul 04, 2019 4:41 pm
by jasonzhou
Can you please try Layout.row and Layout.col in DDS see if it works as expected?
For example:
     A                                 20 20HTML('<<FORM1>>
     A                                      Type: Form
     A                                      Layout.row : 1
     A                                      Layout.col : 1
     A                                      Layout.Width : 50
     A                                      Layout.Height : 50
     A                                      BackColor : Gray
     A                                      ')
     A                                 20 20HTML('<<FORM2>>
     A                                      Type: Form
     A                                      Layout.row : 1
     A                                      Layout.col : 1
     A                                      Layout.Width : 50
     A                                      BackColor : Red
     A                                      ')
     A                                 20 20HTML('<<FORM3>>
     A                                      Type: Form
     A                                      Layout.row : 1
     A                                      Layout.col : 1
     A                                      Layout.Width : 50
     A                                      BackColor : Yellow
     A                                      ')
Posted: Thu Jul 04, 2019 4:58 pm
by MegumiSawada
Hi Jason,
Thank you for your reply.
It seems that only the last definision(e.g. FORM3) will be recognized becase 3 subforms are at the same position.
So the last difinision is shown initially and an error will occur when tapping buttons.
Layout.col and Layout.row doesn't seem to work as expected.
