[RPG/RDMLX]Retrieve Device name
Is it possible to get Device Name from LongRange?
Re: [RPG/RDMLX]Retrieve Device name
Post by jasonzhou »
It's feasible on iOS.
As for another 2 platforms Android and Windows, the device name is a little different from iOS. On Android, the model name will be get as device name; On Windows, the PC Name will be get as device name.
Jason
Hi Jason,
Thank you for your reply.
The customer uses iOS.
Could you please let me know how we can retreive Device name on iOS?
It's not in SystemInfo...
Post by jasonzhou »
Sorry Megumi, my last answer is not clear. I meant we can implement this function in next release, however, current build hasn't had this function implemented yet.
Jason
Hi Jason,
Sorry that I misunderstood your previous reply.
I'll send an enhancement request regarding this via support.
Thank you!
soapagent
Post by soapagent »
This would be a good piece of functionality in LANSA Mobile (which is a close relative of Longrange) as well.
Jim
soapagent
Post by soapagent »
New system value DEVICE-NAME for getting the name of client device
How does this work. Is this a system value like *DEVICE-NAME? I found q_getSystemValue in the docs but how do I access this in RDMLX?
Post by jasonzhou »
Hi Jim,
q_getSystemValue is an ECL function, you can use ExecScript operation to execute an ECL script. Please try out the following example to get device name in RDMLX
RDMLX
Function Options(*DIRECT)
Begin_Com Role(*EXTENDS #LRNG_FORM)
Mthroutine Name(HandleRequest) Options(*REDEFINE)
Define_Com Class(#Prim_Alph) Name(#EnteredText)
#COM_OWNER.Using Element('/Form.Fields')
#COM_OWNER.Set_Form Grid_Col_N(1) Grid_Col_Width(Fill)
#COM_OWNER.Set_Button Name("GETDEVNAME") Text("Get Device Name") Layout_Col(1) Layout_Row(1)
#COM_OWNER.Set_Label Name("RESULT") Layout_Col(1) Layout_Row(2) Color("Red")
#COM_OWNER.Set_Op_ExecScript Event(GETDEVNAME.OnClick) Resource(LRECL_GetDevName.js)
#COM_OWNER.EndUsing
Endroutine
End_Com
LRECL_GetDevName.js
lrexec(
    function()
        this.q_getSystemValue("DEVICE-NAME");
    function(result)
        this.q_setProperty("form.fields.RESULT.Value", JSON.stringify(result,null,4));
Jason
soapagent
Post by soapagent »
Thanks Jason, I'll have a play with that as soon as I can.
soapagent
Post by soapagent »
Would this work from a VLWEB Widget?
var device = this.q_getSystemValue("DEVICE-NAME");
